User
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
Sep 02, 10 at 19:22
1 Hour
1 Day
1 Week
1 Month
Forever
Search
Advanced search
News
If you can't access MARKET FORUM, you have 30+ posts & been a member 30+ days, please PM DENEB or any other mods.
Sister Sites
Our sponsor
Dolls, toys, figures, miniatures, everything you need!
Home
Help
Search
Login
Register
Dollie Mixtures
The Clinic: FAQs & Customizing (All Dolls)
Pullip Links, Tutorials & FAQs
» Topic:
Taeyang to Obitsu Slim Male Body Swap Tutorial
Pages:
1
2
Author
Topic: Taeyang to Obitsu Slim Male Body Swap Tutorial (Read 6340 times)
kaoko
Bentolicious!
OOAK
Offline
Okaeri, Aki-chan!
on:
Jan 13, 08 at 04:04 »
Unlike the Obitsu Normal Male swap, switching from Taeyang stock to Obitsu male is much much easier. Still, I know how it can be daunting to swap the first time so I figured I'd take photos and do a guide as I go along to make the process less scary.
Before you begin, remember to wash your hands and to keep a clean towel nearby. Clean hands = clean dollies.
First off, you'll need a Slim Type Male Obitsu, the accompanying neck pegs, screwdrivers, and teflon tape or rubber bands. I usually keep scissors on hand because they save time when opening packages, cutting tape, and all sorts of things. Of course you need to have your original taeyang too. If you haven't removed the stock wig off your taeyang, do so now. Couldn't take photos of that because Junpei's long been rewigged, but if you don't know how,
Poohki's SB switch guide
explains it very clearly.
Okay. He's been dewigged. The first thing you do is find a spot along the edges of his scalp plate where you can work your screwdriver in. Gently poke and pry until you hear a popping sound.
The popping sound means that the glued part has come apart and you can now pull the scalp off.
The taeyang head has 3 screws keeping the front and back plate together. Unscrew them, but make sure you keep them together in a safe place.
Remove the back plate. Now, you're left with the face plate, the eye mech and the body.
Remove the body from what's left of the head, then lay the head down on a safe, cushioned place. When laying my dolls face down, I place them on clean, soft cloth where there's no chance that it'll be scratched.
Now, take the body and unscrew the neck peg that's attached to it.
Replace it with the largest neck peg.
Wrap the part of the neck that's between the body and the neckpeg with lots of Teflon Tape or High Quality rubber bands. Recently,
an issue has been brought up that low quality rubber bands can cause neck melt
(and has happened to one of my own dolls), so I'm opting for Teflon tape (as vanie suggested) simply because I don't have access to Cauldy's Scunci rubber bands. But if you can get them, they're easier to use than Teflon tape.
Make sure you build up an adequate amount of tape, because it tends to flatten after insertion.
Try inserting the body into the neck hole. Twist it a bit to test for tightness. It should be tight enough to not wobble, yet still allow for turning the head left and right. If it's not, add or lessen tape / rubber bands until you have a satisfactory fit.
Add the backplate. Before screwing it back on, hold the front and back parts tight then experiment moving the neck. If you're still satisfied, screw the backplate on. If you're not, adjust the tape / rubber bands. Make sure to screw the head on tightly---you don't want a doll with a screw loose. ^_^;; (Although I seriously think no amount of tightening will ensure that for Junpei.)
Attach the scalp plate back on. There are may ways of sticking it back. You can use velcro, glue, or blutak. Whatever you do, don't use superglue or any glue that can't be undone. You never know when you'll need to reopen their heads. Plus, a lot of owners have said that superglue eats through pullip plastic. O.o Personally, I use blutak / tack-it. The backside is that it stains but then, I don't mind since it'll stain a concealed place anyway.
Stick the scalp on, then slip his wig back into place. Slim Obitsu body swap success! Awful skintone match, neutral on a Sage but I'm not sure if I can
tone the right skin tone
on him. In the meantime, he'll have to stay clothed.
You now have a lankier boy with more body motion. Congrats!
The first few steps might confuse you if you have a newer boy. I don't know when they switched, but between Sage and Butler, the heads have been changed. From a 3-part head with three parts (front, back + scalp), we now have a 2-part head, that only comes with front and back plates. Not much diff obitsuing-wise. You just don't have to pry the scalp off. (Suggestion, to avoid complaining dolls, ply them with tequila until they fall asleep! Seiji slept through the whole obitsu process!)
Lastly, slim obitsu bodies (not sure with normal male) have extendable legs. Simply detach the legs at their connection points then slip in the extenders. Instant longer legs!
Cross-posted at
This Doll's Life
http://dokidoki.kitchencow.com
http://www.kitchencow.com
http://kaoko_cow.livejournal.com
Lives with:
Aki (Nina), Seiji (Butler), Junpei (Sage), Sachiko (Veritas), Grey (Horizon), Wills (William), Sophie (Celsiy), Suzu (Colline) and Sam (Rovam).
Yun
Tirelessly stalking her dolls...
OOAK
Offline
Gender:
I do what my dolls tell me to do
Re: Taeyang to Obitsu Slim Male Body Swap Tutorial
Reply #1 on:
Jan 13, 08 at 08:17 »
This is great, Kaoko!
Your method is much better than mine, I don't change the neck piece and just use rubberbands... That melt.
For the newer heads: It started with Lead, but I've heard some Lead's still have the 3-piece head. But just in case you have Lead or any doll released after, you're likely to have the newer head. (Be happy, it's easier as you don't have to bother with removing and re-attaching the scalp!
flickr
LJ
kaoko
Bentolicious!
OOAK
Offline
Okaeri, Aki-chan!
Reply #2 on:
Jan 14, 08 at 13:43 »
Quote from: Yun on Jan 13, 08 at 08:17
I think not all rubberbands melt. I guess it's just a matter of choosing the right brand? I was horrified to find that Aki had neck melt though. But I haven't had the chance to switch her over to teflon tape yet.
And it's funny, some Leads have 3 piece heads and some don't. It's like...not all Leads are created equal, hehehe!
Lives with:
Mayonaka
Dollies are Yummy!
Global Moderator
OOAK
Offline
Gender:
Reply #3 on:
Jan 14, 08 at 14:01 »
Okay, I have a question. Are the leg extenders for gay male couples where you have a seme and an uke and you have to make them taller so that they're not the same height?
Home:
Sakana
(Hello Kitty),
Makoto
(Lead), Yua (Tezca), Chie (Coral), Beatrix (Puki), Mushu (RIDa), Asad (Captain Hook)
poohki
Why is the rum always gone?
Administrator
OOAK
Offline
Gender:
The Haylenator!!!
Reply #4 on:
Jan 14, 08 at 16:39 »
Excellent tutorial, Kao! I stickied it for you. I had no idea that Obitsu male bodies came with leg extenders!
What a great idea! Now I wish the girl bodies had those too, so they don't all have to be the same height.
Poohki's Flickr
Yun
OOAK
Offline
Gender:
Reply #5 on:
Jan 14, 08 at 17:01 »
Quote from: Mayonaka on Jan 14, 08 at 14:01
I never thought of that!
I never used those extenders on my boys, but Kazuya still is taller than Ren, I only just noticed!
(But I'm very sure he's not using the extenders...)
flickr
LJ
kaoko
Bentolicious!
OOAK
Offline
Okaeri, Aki-chan!
Reply #6 on:
Jan 15, 08 at 02:30 »
*facepalm*
Sadly, I have a friend who's getting Obitsus on the Taeyangs she's set to get for that exact same reason
Quote from: Yun on Jan 14, 08 at 17:01
It's his natural seme-ness showing through.
And thanks for the sticky, Poohki
Hope people find this useful!
Lives with:
Mayonaka
Dollies are Yummy!
Global Moderator
OOAK
Offline
Gender:
Reply #7 on:
Jan 15, 08 at 15:47 »
I just thought I'd ask.
I would probably do that to Nick and Edgey.
(My boyfriend and I decided that even though he's taller, Edgey's fear of earthquakes trumps him uke status.
Home:
Sakana
(Hello Kitty),
Makoto
ichinose
Hawtness never dies
OOAK
Offline
Gender:
CHOMPCHOMPNOMNOMNOM
Reply #8 on:
Jan 21, 08 at 04:49 »
Awesome XD That cracked me up so much. Cayenne is using the leg extenders after I found out what they're for
But if he's seme, no one's uke.
Great tutorial, kaoko! I don't have Teflon tape with me right now, or I would have changed Cayenne's neck to that. Apparently the good quality rubberbands tend to slide down the neck piece, making the upper torso pop open
Faceup commissions
lost in translation
woo!flickr
Inga
Equal Opportunity Dollie Addict
Administrator
OOAK
Offline
Gender:
Mixing Dollies, for fun and profit!
Reply #9 on:
Jan 21, 08 at 11:03 »
I can't decide whether to obitsu my boy (I like his current muscles!) but the entertainment value of this tutorial alone had me glued!
kaoko
Bentolicious!
OOAK
Offline
Okaeri, Aki-chan!
Reply #10 on:
Jan 21, 08 at 14:17 »
From information thread to Boys' Love central in just three posts! That must be a record!
Quote from: ichinose on Jan 21, 08 at 04:49
You're in Singapore right? It's so easy to drop by Kaya's and grab one of her boys to be uke, heeheehee.
Lives with:
Kaya
Commanding the Sexy Boy Army, breaking Pullip hearts across the world!
OOAK
Offline
枷椰
Reply #11 on:
Jan 22, 08 at 00:36 »
Quote from: kaoko on Jan 21, 08 at 14:17
Ah ha~
I hear that I hear that, Kaoko
Kaya*s WaWa~ ~Nanako~Naeko~Sakito~Gin~Xinn~Hsin~Sho~Aurora~Ean~Kai~Miso~Bubble
~Galren~Raeanne~Joshe~Asagi~Ameko~Bei~Kane~Champagne~Ikki~Vericia~Nickholas
~Mikan~Seraphine~Zaccheus~Tea~Reizo~Xuiyin~Fang Ning~Teru~Nicodemus~Izumi~Crayon~Nika~Junya~Erasmus~Jin~Melize~Belle~Alperen~Nashi~Soshi~Rayne~Sebest/Dexter~Shinku~TuEn PukiYo~Lyon~
ichinose
Hawtness never dies
OOAK
Offline
Gender:
CHOMPCHOMPNOMNOMNOM
Reply #12 on:
Jan 22, 08 at 08:55 »
Quote from: Kaya on Jan 22, 08 at 00:36
Ah ha~
So, Kaya, which one of your boys are uke?
Faceup commissions
lost in translation
woo!flickr
Kaya
OOAK
Offline
枷椰
Reply #13 on:
Jan 22, 08 at 10:22 »
Quote from: ichinose on Jan 22, 08 at 08:55
Ah ha~
Oopx...... wat's uke means... I still dunno... so paiseh
Mayonaka
Dollies are Yummy!
Global Moderator
OOAK
Offline
Gender:
Reply #14 on:
Jan 22, 08 at 12:50 »
Quote from: Kaya on Jan 22, 08 at 10:22
Ah ha~
Uke is like the female in a male-male relationship. Seme is more dominant
Home:
Sakana
(Hello Kitty),
Makoto
Pages:
1
2
Please select a destination:
The Police Station: Welcome, Rules, Help (All Dolls)
=> Technical
===> FAO (For the Attention Of)
=> Introductions
Pullip Avenue
=> General Chat
=> Photo Gallery
===> Dolly Profiles
Blythe Boulevard
=> General Chat
=> Photo Gallery
Momoko Lane
=> General Chat
=> Photo Gallery
===> Dolly Profiles
BJD Drive
=> General Chat
=> Photo Gallery
===> Dolly Profiles
Mini Playground: Dollcena, Petite Blythe, Mini Pullips
=> Chat
=> Photo Gallery
The 'Burbs: Other dolls - Barbie, Mimo, etc
=> Chat & Photo Gallery
=> Pullip Links, Tutorials & FAQs
=> Pullip Mug Shots
===> Pullip Custom Gallery
=> Photo Requests
=> Blythe Links, Tutorials & FAQs
=> Blythe Custom Gallery
The Shopping Mall: Buy, Sell, Trade (All Dolls)
=> Bulletin Board
The Countryside: Other & Misc.
=> Games
===> Demographics
=> Off Topic Chat
=> Artwork
Powered by SMF 1.1 RC3
SMF © 2001-2006, Lewis Media
Epsilon
design by
Bloc
